Sound Powered phones
Shawn72
11 Feb 2015
Selling sound powered phones and parts as a lot.
20 phones
15 elements
5 switches
4 cords
Most parts are used, some are new. Cords have various plug ends. Not sure of status of phones. Selling because I went with a different system. $1000.00 for the lot.
20 phones
15 elements
5 switches
4 cords
Emax
11 Feb 2015
20 phones
15 elements
5 switches
4 cords
20 phones
15 elements
5 switches
4 cords
Which system did you go for?
Shawn72
12 Feb 2015
Just some regular phones with a 12Vdc power supply in line. Picked the power up off of 1 of my 24Vdc batteries. Clear and reliable.
Emax
13 Feb 2015
Shawn72
14 Feb 2015
Emax
15 Feb 2015
Shawn72
17 Feb 2015
Emax
17 Feb 2015
hillsparky
05 Apr 2015
We use standard 2554 wall phones with amplified handset which makes it great for noisy places like motor houses or under the drive terminals. To provide the "talk battery" we have built a small box to house the terminal strip, LED indicator, a fuse holder, and a small voice transformer. The transformer is a 600 ohm to 600 ohm transformer with the one 600 ohm winding split, NOT center tapped. You place a 1uf capacitor across the split of the winding and feed your 24 volts filtered DC across the split as well. 12 volts DC will work but it seems that the 24 volts is better. "Tip" and "Ring" for the telephones comes from the main leads of that winding on the transformer. The capacitor maintains the 600 ohm impedance for the audio and the split coil provides the loop current needed for the talk circuit. The non split winding, or secondary winding, is not used. It is simple and straight forward and the phones get hooked up to the circuit just as if it was a standard phone line. No need to worry about series circuits or any other special switches or such.
Steve
Steve
TCOTTAM
26 Aug 2015
INTERESTED IN BUYING THE SOUND POWERED PHONES DO YOU HAVE A PHONE NUMBER I CAN CONTACT YOU AT. PLEASE EMAIL ME AT TCOTTAM@ANGELFIRERESORT.COM
Shawn72
22 Oct 2015
timberlaker
23 Oct 2015
The ansi code states reliable communication. What if you loose your 24v supply. It is a plausible scenario.
hillsparky
25 Oct 2015
Yes loosing the 24v supply is possible. We use the 24v source that supplies the control voltage. As long as you have your control voltage source (batteries and chargers) you have communications.
Emax
26 Oct 2015
First, ANSI is not a "code" - it is a standard.
Second, based on experience, sound-powered phones are not very reliable ... subject to a multitude of failures.
Standard analog telephones are much more reliable - even if powered by system voltage.
iceberg210
26 Oct 2015
In a day with radios and cell phones I would argue that a 24 V system is plenty reliable and if you don't have control voltage you've got larger problems than communication...
timberlaker
31 Oct 2015
Code: a set of rules and standards adhered to by a society. We are forced to adhere to said Standard are we not? Semantics some may say. It is Halloween why not split some hairs. Either way this is the classic Po-Ta-Toe vs PO -tay-toe issue. If cared for Sound powered phones are reliable. I have had both but have always inherited the Viking type not the aforementioned method so in all fairness I should give the aforementioned method a try.
DashHopes
23 Nov 2015
We use 6V telephones with no problems. I'm curious to how the sound powered phones operate?
timberlaker
13 Dec 2015
Why the sound pressure from hour voice causes a diaphragm to move a conductor through a magnetic field and creates current. That current then travels to the other end of the lift where the reciprocal happens. Except your ear is on the diaphragm at the other end.
Would you be kind enough to post a link to the supplier of your 6v phones?
DashHopes
16 Dec 2015
We use the Econocom phones.
WWW.metragenll.com/hardwire_intercoms.html
Christine Carnovale is our Rep there.
