This post has been edited by Snowy Ferries: 27 July 2014 - 10:06 PM
Can two types of terminal styles be used on one lift?
#41
Posted 27 July 2014 - 10:06 PM
#42
Posted 25 October 2014 - 05:51 AM
Skier123, on 07 September 2009 - 12:52 PM, said:
Here's the bottom:
And here's the top:
That Bottom Station is a Yan (at the time the picture was taken)
Nowadays, It's a poma.
Keep in mind, that bottom station had to be fitted for the TB-41 grips and possibly new bullwheel/tensioning/drives, I don't know much about Yan HSQ's either. It strikes me as odd: Poma, I don't think, carried this terminal in 2011-2012 when the bottom station was rebuilt, probably custom made to match the summit terminal.
From NESkihistory, here's the new bottom station:
Grand Summit Express 2014.jpg (78.62K)
#43
Posted 25 October 2014 - 09:45 AM
All the terminals in question are all retrofitted LE terminals for Poma TB-41 grips. All that was done in 2011 was a fully inclosing skin was added vs the minimal skin it had before.
#44
Posted 22 November 2014 - 04:45 PM
I know of a lift where I live where the bottom drive station is a CLD-4 while the top return is a UNI.
(Bethlehem Express @ Bretton Woods) *Photos aren't mine of course* (Computer's derping out on me)
#46
Posted 23 November 2014 - 09:14 AM
Both those terminals are the same early uni designs the bottom looks different because it houses the drive. On that model lift, at least, one station is passive spacing and the other is active. My experience was with Timberline Express at Copper which is a similar lift. BTW if active spacing was turned on at both stations on TEX bad things happened
#47
Posted 23 November 2014 - 03:04 PM
This post has been edited by DonaldMReif: 23 November 2014 - 03:04 PM
#48
Posted 25 February 2015 - 04:23 PM
Bottom:
Top:
Also, you could argue that the top and bottom of the gondola at loon are "different" because the top drive has a tan building covering the machinery while the bottom tension and cabin parking is exposed, but located in the base lodge. I don't know if there is any major differences between the top and bottom, but it is very interesting to see all of the moving parts working together to keep it running.
#49
Posted 25 February 2015 - 04:39 PM
#50
Posted 25 February 2015 - 04:50 PM
#51
Posted 26 February 2015 - 06:10 AM
#52
Posted 27 February 2015 - 04:39 AM
All Doppelmayr detachable quad chairs are CLD-4s, this is short hand for the carrier type, grip type and number of passengers. UNI is the enclosure name. The Bethlehem is fine spacing top, rough spacing bottom. I forget is 'passive' is fine or rough.
#53
Posted 27 February 2015 - 05:43 AM
#54
Posted 03 March 2015 - 05:48 AM
That lifty at the Bethlehem needs a haircut... and he wore his pajamas to work.
wbl
#55
Posted 05 March 2015 - 06:34 PM
#57
Posted 17 March 2015 - 05:05 PM
#58
Posted 17 March 2015 - 05:19 PM
DonaldMReif, on 17 March 2015 - 05:05 PM, said:
The larger windows were only used in North America for one year (1995)
Posted 17 March 2015 - 05:28 PM
