This post has been edited by DonaldMReif: 21 January 2015 - 11:36 AM
New Lifts 2015
#121
Posted 21 January 2015 - 11:35 AM
#125
Posted 22 January 2015 - 06:57 AM
#126
Posted 24 January 2015 - 11:15 AM
Posted 24 January 2015 - 01:09 PM
Obviously the interconnect gondola and King Con are going to be brand-new lifts. The way the text is phrased says that the high speed quad that will be replacing Motherlode will also be all-new infrastructure, instead of the old King Con being relocated. Perhaps the parts from the original King Con quad will find a different use.
I'm sure that's a typo because Chair 4 is the Mountaintop Express lift, and Doppelmayr upgraded that lift to the current six-pack last year. It shouldn't need to be upgraded any further. Obviously, the writer's hand slipped and typed a 4 when he meant to type "Chair 2", as Chair 2 is the Avanti Express lift . Nonetheless, since that is a profile involving an interview with someone in the lift construction industry, and the person talked to is Doppelmayr's CEO, that one line pretty much is confirmation that the Avanti Express lift will be a Doppelmayr lift (and I think it will be only the fourth Doppelmayr-built high speed six pack in Colorado, after the Purgatory Village Express, the Mountaintop Express, and the Centennial Express lift).
This post has been edited by DonaldMReif: 24 January 2015 - 08:17 PM
#129
Posted 24 January 2015 - 10:55 PM
#130
Posted 24 January 2015 - 11:13 PM
matt9915, on 24 January 2015 - 07:53 PM, said:
The problem is that the only spot uphill that would access any other blue runs is the top of Crescent. That is a long traverse that has questionable coverage from where the main King Con pod is. They need to work on the Gotcha Cut Off area if they really want to move traffic out of the area. I feel like most people exit the King Con pod via Silverlode because of how nasty Gotcha can be. Personally, if the slalom was skiable, I took that but as it's east facing at low elevation, coverage was often sketchy.
#131
Posted 24 January 2015 - 11:40 PM
#132
Posted 25 January 2015 - 09:03 AM
#133
Posted 25 January 2015 - 09:14 AM
I guess Pioneer could be in a position where Old King Con could be repurposed to replace it if PCMR wanted to do that. Although it seems to me Vail Resorts might need to do more work on the Canyons side of the interconnect to actually facilitate smooth transportation between the two ski areas. By that, I mean building additional lifts so that people wanting to go from the PCMR area over to the areas where Orange Bubble and Super Condor can do so without using Tombstone (a two-way lift from the Canyons base to the bottom of Tombstone looks really attractive, but alas, it probably won't happen), and various lift upgrades to make traveling back that way much easier (read: upgrade/realign Peak 5 and Day Break, and upgrade Dreamcatcher).
This post has been edited by DonaldMReif: 25 January 2015 - 09:23 AM
#134
Posted 05 February 2015 - 01:35 PM
Posted 05 February 2015 - 03:21 PM
#137
Posted 05 February 2015 - 06:40 PM
#139
Posted 05 February 2015 - 07:55 PM
#140
Posted 06 February 2015 - 07:19 AM
