Questionable Lift Installations
#81
Posted 26 November 2014 - 11:04 AM
#82
Posted 26 November 2014 - 11:16 AM
Peter, on 15 May 2014 - 07:08 PM, said:
I don't exactly know... I ski Ragged a lot. I agree, a six-pack isn't necessary, but keep in mind that their six pack is a low-capacity. (It has 1800 pph compared to "normal" 3600)
One guess I have for it''s installation would be Ragged trying to be a big shot installing the first HSSP in the state of NH.
#84
Posted 26 November 2014 - 03:56 PM
I say that it made sense to put The Cabriolet where it is now and not where the triple is. The triple required you to take a run on Triple Bound to even reach it which is a pointless, flat, cat track. The Cabriolet starts right next to the lodge, so you walk out of the lodge and right to the loading area.
#85
Posted 26 November 2014 - 05:21 PM
Kicking Horse, on 26 November 2014 - 03:22 PM, said:
True, actually. According to the Concord Monitor, Ragged got the six pack for 1.8 million.
Also, the only way skiers are going to be able to reach the future "Pinnacle" area is by the six-pack to Easy Winder. (I would assume Easy Winder would need snowmaking though.)
#86
Posted 16 December 2014 - 01:22 AM
C lift is actually shorter (Timewise), you gain vert and like others have said you can avoid the flat traverse if you don't want to take Frosty's Freeway to E-Chair.
This post has been edited by llamborghinii: 16 December 2014 - 01:22 AM
#87
Posted 16 December 2014 - 07:49 AM
Lift A starts downhill from the bottom of the Mercury SuperChair and at the top of the hill on Red Rover that merges with Sundown at the Peak 8 SuperConnect. It mostly is meant to be used by beginners, and even then, it's only used during weekends and peak periods to handle crowds. Lift C does have vertical, but it only really reaches the four runs on Peak 9 north of Sundown and, like Lift A, only sees use during weekends and peak periods. Although, at least one master plan proposal suggests removing Lift A, and replacing it with a high speed quad that has a midway unload turn station where the current Lift A's midstation is, then travel up to end at a point where people currently can cross over between Briar Rose and Cashier. Said master plan proposal didn't include a Peak 6 expansion that happened like actually unfolded, but it did include a six pack Colorado SuperChair (which has happened) and also called for upgrading Lift C to a high speed quad.
#88
Posted 16 December 2014 - 02:12 PM
A is very pointless now but in Breck's defense, the lift made perfect sense when it was installed. The lifts layout has changed a lot in the last 40 years but back then A was the most direct way to access B. A was also the only lift on that part of the mountain (Mercury, Quicksilver & Super Connect didn't exist yet and Beaver Run was a much shorter lift known as D) Take a look at the old map linked below for more details.
https://skimap.org/d.../1286751272.jpg
#89
Posted 16 December 2014 - 03:43 PM
#90
Posted 30 April 2015 - 01:27 PM
#91
Posted 30 April 2015 - 02:13 PM
snoloco, on 30 April 2015 - 01:27 PM, said:
Higher capacity lift = overcrowded trails. The Mansfield side of Stowe is a skiers mountain and more polluted trails would take away from the experience. Might also have to do with being on State Forest land. My $0.02
#94
Posted 01 May 2015 - 06:34 PM
Don't touch Mansfield lift capacity. Just move the Quad down next to the base lodge, and I'll be happy.
#97
Posted 23 July 2015 - 04:37 AM
#98
Posted 20 March 2016 - 04:58 PM
It should run every day from 10am to midnight so that it actually serves the casino like it is supposed to. They'd get many more users that way than as a transfer lift between two points that skiers rarely need to move between.
#99
Posted 20 March 2016 - 06:23 PM
It would be a great lift to lap if it ended on the groomed part of the alpine bowl run. Unfortunately it ends on a rough part and makes it not easy to lap because you have to push yourself up the hill to the groomed part.
Squaw One at Squaw Valley
I really like this lift, but the bottom terminal is in an undesirable location that you have to push yourself across the snow to get to and it ends in the middle of nowhere. This lift is good to have because it is mine and a lot of other peoples secret lift to avoid the funitel lines.
-Will
#100
Posted 20 March 2016 - 07:15 PM
The biggest issue with this lift is the location of the top terminal. In any sort of storm or night wind event it cannot be run unless/until the headwall face has been cleared for avalanche control. Thus between that constraint and the fact that the funitel serves the same terrain it does not run as much as it could. I do agree that it is a great lift for circulation when it runs.
9 User(s) are reading this topic
0 members, 9 guests, 0 anonymous users
