New Lift Construction Photos 2014
302 replies to this topic
#21 SkiDaBird
  • 509 Posts:
Posted 20 April 2014 - 02:25 PM
View Postsnoloco, on 20 April 2014 - 02:13 AM, said:
Who would be against having easy access to terrain without needing to hike?!
Those who already hike the terrain. It kinda removes the powder when a lift is installed.
#22 Nate214
  • 266 Posts:
  • Interests:Skiing, snowbiking, mountain biking, camping, hiking, cars
Posted 20 April 2014 - 03:11 PM
Right we have other hike to terrain this lift will be an awesome upgrade to our mountain
#23 missouriskier
  • 187 Posts:
  • Interests:Skiing, Operating Construction Equipment, Driving
Posted 20 April 2014 - 04:03 PM
View PostNate214, on 18 April 2014 - 09:17 PM, said:
Pictures for you. The 13.5ft diameter 6,800 lb Skytrac bullwheel now sits at 12,481ft waiting for construction of the new triple Mainstreet lift. The sled weighed 1,800lbs for a total 8,600lb haul up 1,078 ft vertical Kachina peak. The Haul was a great success and had a little protest written in the snow.Attachement kachinab.jpgAttachement kachinab0.jpgAttachement kachinab1.jpgAttachement kachinab2.jpgAttachement kachinab3.jpgAttachement kachinab4.jpg
Thanks for the photo update. Looks like it went pretty well. It looked like they had another cat at the top for a winch anchor, correct?
Also, Telluride has 12,570 feet as the top elevation of the Revelation Quad, so unless that number's wrong this would be the 4th highest chairlift. Also the Cirque Poma at Snowmass is 12,510, I think.
#24 Nate214
  • 266 Posts:
Posted 20 April 2014 - 05:24 PM
Thanks for the update
#25 Nate214
  • 266 Posts:
Posted 20 April 2014 - 07:22 PM
They used a big rock up top for the anchor then once they had a cat up there they used it to help winch the weight of the load which was also being pulled by a winch cat so they were sharing the load. I will take 4th highest chairlift since the cirque is a platter. The stats I found must have been old cause revelation lift was installed about 5 years ago right and was not on the list when I looked up this info.
This post has been edited by Nate214: 20 April 2014 - 07:23 PM
#26 jaytrem
  • 217 Posts:
Posted 21 April 2014 - 04:25 AM
Well at least that answers our question from another thread. It becomes the highest triple chair in North America.
#27 Nate214
  • 266 Posts:
Posted 10 May 2014 - 07:04 AM
Another picture of the Sky Trac Bullwheel on Kachina PeakAttached File  kachinab5.jpg (55.25K)
#28 DonaldMReif
Posted 10 May 2014 - 09:45 AM
I assume they'll air-drop the rest of the parts for the upper terminal given the location.
#29 vons
Posted 10 May 2014 - 10:58 AM
yes, they hauled the bull wheel up with the cats because it would have required a much larger and more expensive helicopter to pick it than what is needed for concrete and towers. I have seen some pictures on the taos chamber of commerce Facebook page, it looks like the rebar and form work materials where also hauled up.
#30 Lift Dinosaur
  • 2,077 Posts:
Posted 10 May 2014 - 12:20 PM
So my question is- "How are they going to make it jump up into the return frame?" :unsure:
#31 vons
Posted 10 May 2014 - 02:29 PM
I have the idea that the design of the return was changed on this lift to make that process much more simple
#32 Nate214
  • 266 Posts:
Posted 11 May 2014 - 05:15 AM
Everything else will be flown. Our bullwheel is designed to hang under the return structure instead of on top so it can be lifted into place easier
#33 Yooper Skier
  • 237 Posts:
Posted 13 May 2014 - 01:26 PM
Attached File  cupidjpeg.jpg (53.47K)
Number of downloads: 112Stopped by Granite Peak on April 27th and the chairs were off of Cupid.
#34 RibStaThiok
Posted 13 May 2014 - 03:42 PM
tugs at the heart, doesn't it.
#35 liftmech
Posted 14 May 2014 - 07:17 AM
First tower's up on the Park King. Finishing flying concrete today.
  • Attached File  image.jpg (71.26K)
#36 vons
Posted 14 May 2014 - 04:41 PM
I saw some buckets flying in the park web cam, does this lift have to be ready for the summer camp?
#37 Lift Dinosaur
  • 2,077 Posts:
Posted 14 May 2014 - 10:03 PM
Park King...catchy name...
Good to see you in G.J. Have a great summer!
#38 skierdude9450
Posted 15 May 2014 - 11:14 AM
Where exactly on the mountain is it being installed?
#39 DonaldMReif
Posted 15 May 2014 - 12:06 PM
That's the Union Creek lift in the background of liftmech's photo. I'd say it's where the Woodward Terrain Park is or somewhere near it.
#40 vons
Posted 15 May 2014 - 03:33 PM
you can see the build on the woodward park web cam.http://www.coppercol...in%20Park/index
