Design Speed vs. Normal Operating Speed
Posted 23 March 2014 - 04:17 PM
Mountain Creek: Their two high speed quads and cabriolet gondola are rated for 1,000 fpm. Although I have seen them run at this speed, they often don't, especially midweek.
Hunter Mountain: The Kaatskill Flyer runs at the full 1,000 fpm whenever weather conditions permit. Sometimes they run it slightly slower if they have a lot of stops or if it is windy. The Zephyr Express doesn't get crowds and usually doesn't run at its design speed, although they have been running it more at its design speed this year.
Whiteface Mountain: Their gondola is rated for 1,200 fpm but usually runs slightly slower since its route gets a lot of wind.
Stratton Mountain: Their four 6-packs seemed very fast when I rode them. These had to be running at their full design speed which is probably between 1,000 fpm and 1,100 fpm. Their gondola sure wasn't fast. I didn't time it, but it felt like it was running around 800 fpm most of the day.
Killington: Ramshead is rated for 1,100 fpm, but it is usually run at 800 fpm because of high volumes of beginners. It stops a lot even when running at that speed. If it ran at 1,100, it would stop even more. Skyeship is rated for 1,200 fpm and runs that speed most of the time, unless wind prevents them from doing so. K1 is rated for 1,000 fpm and runs at that speed all the time unless it's windy. Their other detachables are the same.
Gore Mountain: Their gondola is rated for 1,110 fpm, but is usually run at 850 fpm. It never runs 1,110 and is only run faster than 850 when the line gets long. This is either done to keep wear and tear down or because of loading/unloading issues.
What is usually done in terms of lift speeds at other mountains? I would imagine that it is similar to what is done at the mountains listed above.
Posted 24 March 2014 - 09:22 AM
Posted 24 March 2014 - 05:20 PM
Posted 03 April 2014 - 02:53 AM
mrskifriend, on 02 April 2014 - 08:33 PM, said:
This has happened to me at Mountain Creek. They ran South around 800 fpm and Bear around 700 fpm for many days late in the season. These are designed for 1,000 and they turned them up to 1,000 as soon as they got everyone off at the end of the night so that they could flip chairs faster and go home sooner. That is really sad.
Posted 03 April 2014 - 04:39 AM
Posted 03 April 2014 - 02:58 PM
This post has been edited by 2milehi: 03 April 2014 - 02:58 PM
Posted 04 April 2014 - 04:33 AM
I have never skied in Europe, but my understanding is that people often pay by the ride, not by the day. Is that right? In that case it might make more logic as a slower lift means less rides and less income for the mountain also.
Overall it seems there is an uncomfortable tension in how lift / mountain prices are set compared to what skiers want and expect.
I dont know, just thoughts...
TME
Posted 04 April 2014 - 03:25 PM
TME
At $275 a year I have no right to complain about line speed. My 2 cents.
#13
Posted 07 April 2014 - 05:24 AM
2milehi, on 24 March 2014 - 05:20 PM, said:
I am certain it has to do with the fact that Breckenridge realized that the Independence SuperChair was going to receive a lot more skier traffic as you must use the lift to get back to Peak 8 base after you are done lapping the Kensho SuperChair.
#14
Posted 17 April 2014 - 09:21 AM
Posted 10 January 2015 - 06:28 PM
When they turned the lift down to 800fpm, the chairs moved so slowly in the terminal that the next people to load would frequently hit the chair in front of them, this sometimes caused people to fall and the lift to stop and slow constantly. When running full speed, the chair in front of you leaves the ramp quicker so you aren't in as much danger of hitting it. Getting off was also a challenge when the lift ran slow. The chair wasn't going fast enough to give you enough momentum to smoothly unload which was especially tricky on snowboard. People would often get hit by the chair as it went around because it wasn't going fast enough for people to get enough momentum to clear the ramp. Today I found it much easier to unload with the chair at a slightly faster speed. There were less stops and slows as well due to unloading issues.
I wonder if there are cases when running the lift faster will reduce stops/slows. It seemed like that was the case here.
Posted 11 January 2015 - 07:01 AM
Posted 11 January 2015 - 11:31 AM
Posted 11 January 2015 - 12:02 PM
Posted 11 January 2015 - 12:36 PM
