Scariest lifts to ride
Started by Lift Kid, Feb 13 2006 03:18 PM
128 replies to this topic
#121
Posted 03 February 2014 - 03:49 PM
The South Peak Express at Mountain Creek can be very scary to ride at times. It is not the lift itself, it is the people who use it. I have many times ended up on it with people who do drugs/alcohol, ask weird questions about sex, and many other things. I avoid it like the plague unless the line is short enough to ride it alone, or if I am with friends and we can get the chair to ourselves.
#124
Posted 16 October 2016 - 09:38 AM
Summit Quad at Whiteface: Just after getting on, you go over a creek, where the lift is really high up. If you drop a pole or glove, it's gone forever. The last 3rd of the lift consists of going up what feels like a near vertical wall. Because it's one of the highest elevation lifts in the east, the trees are shorter and the lift is above them, making the lift seem higher off the ground that it actually is. It's also very exposed to wind at that point, so the chair can swing a lot.
The Lookout Triple to looker's right is lower to the ground and more protected from the wind, even though it goes almost as high up. The Little Whiteface Double is also a bit of a scary one because for the top half of the route, you're up over the low side of a double fall line, meaning the lift is higher up than it would otherwise be.
#125
Posted 16 October 2016 - 12:49 PM
black mountain triple. there's a double tower that's two very large pylons stacked. it's sketch
The Ski Lift Enthusiast
#127
Posted 17 October 2016 - 02:36 AM
maine
