Wind tolerance
Posted 15 January 2014 - 07:36 AM
I don't know the answers to these questions, but I'm basing them on my experiences from Breckenridge, as Breckenridge is pretty notorious for strong winds, especially on the above-timberline chairlifts (Imperial, Lift 6, the T-Bar, and the Kensho SuperChair). I do know that the highest wind tolerance for any chairlift is dependent on design and location, but I would like some more specifics.
Posted 15 January 2014 - 06:52 PM
Posted 15 January 2014 - 07:24 PM
For example Marmot chair's levels are as follows:
Level 1: Winds average 20 mph
Level 2: Wind gusts 30-40 mph. Monitor chair swing and be ready to slow or stop lift. Load each chair to its designed capacity - no singles.
Level 3: 4 gusts to 45 mph within 15 minutes. Stop loading and run people off at appropriate speed.
Level 4: Gusts 45-50+ or steady high winds. Stop lift and stop loading. If possible, run people off at slow speed. Be prepared to stop lift again and wait until winds subside to run people off.
These are just guidelines and do not take into account wind direction.
Each lift is different. The new Casper lift has auto-slow and auto-stop features that can be set to specific windspeeds. For example, yesterday auto slow was set to 40 mph and auto stop was at 50 mph. The Tram has clinometers in each car that measure swing. It automatically stops if either car swings more than 9 degrees laterally.
Posted 18 January 2014 - 03:03 PM
- alpentalic likes this
- Like This
Posted 19 January 2014 - 08:11 PM
Posted 21 January 2014 - 11:11 PM
Posted 22 January 2014 - 07:53 AM
SkiDaBird, on 21 January 2014 - 11:11 PM, said:
Mountaineer at Deer Valley, built the same year as Little Cloud, has the slat backrests too, probably also for wind issues at the top (certainly not for comfort). The old fixed quad there was one of the first to shut down in high winds.
Posted 22 January 2014 - 08:28 AM
Posted 22 January 2014 - 04:43 PM
floridaskier, on 22 January 2014 - 07:53 AM, said:
I hate those things. Hope it isn't standard now. Does Mountaineer have normal width towers or does it have the wider 6 pack towers? Deer Valley is a little outside my price range...
#13
Posted 23 January 2014 - 09:17 AM
SkiDaBird, on 22 January 2014 - 04:43 PM, said:
Regular width towers there, and they reused the old tubes. They shortened the second to last tower quite a bit from the old lift and made it a 4-4 compression assembly.
#14
Posted 31 October 2014 - 08:06 AM
Allan, on 15 January 2014 - 10:10 AM, said:
Hi Allan, I found this very useful, but I'm looking for Doppelmayr 4-CLF, (fixed chairlift). In case you have it available could you upload it? Or could you paste a link where it's available to download? Thank you in advance.
Posted 31 October 2014 - 09:11 AM
It used to be that high wind areas and above timberline would be serviced by surface lifts- I have really ridden one in a measured 70mph wind with gusts above that- and then wondered how we were going to get down in the white out. You could spend a lot of money on special design measures to gain several mph on the safe limit only to find a situation that no one had ever thought of( and it will be occurring at a terrible time as well) When you reach that 45-50 range you need to consider WHY take the risk. The guests will get on a running lift if it were carrying them directly into a raging inferno- we need to make the call using not just the anemometer, but experience and direct observation.
- Like This
Posted 31 October 2014 - 11:43 AM
#17
Posted 31 October 2014 - 12:29 PM
Posted 31 October 2014 - 04:10 PM
The second page of that document is from a 4-CLF manual.
Posted 13 January 2015 - 05:08 PM
(Video credits : abl3956)
https://www.youtube....h?v=mkVD3h1B4ok
I actually went to Wildcat one day, in which winds were reaching speeds of up to 200 mph. (Mount Washington area is notorious for record setting weather and wind speeds)
The Wildcat Express, and Bobcat were both fine. Bobcat is mostly tucked away, but the Wildcat Express was taking 200 mph winds directly on the line, not to the side. So basically I was getting blasted in the face with wind and don't get me started on unloading... (I almost went back into the next chair coming by :P)
As for Tomcat, that was shut down (emergency traffic lift pretty much nowadays) and Snowcat I have no clue about that one.
(EDITED) And yes, there already appears to be some disbelief, just let me say that I didn't read a measuring, and I highly doubt it was 200 mph but it was pretty damn high, likely to be less than 100. Ski patrol guy on the Express told me 200, but I find that hard to believe.
This post has been edited by NHskier13: 15 January 2015 - 05:06 PM
Posted 13 January 2015 - 06:31 PM
