←  Skilifts.org Images
Lift Construction Photos 2013
floridaskier's Photo floridaskier 14 Jan 2014
View PostDonaldMReif, on 14 January 2014 - 06:23 AM, said:
It is now interesting comparing both of Wolf Creek's high speed quads given that they have different Doppelmayr designs: both have DT-104 grips, but the Raven Express has UNI-GS terminals and Garaventa chairs, while the Treasure Stoke Express has UNI-G terminals and EJ chairs. I'd go down to do a photo tour of the Treasure Stoke Express lift like I've done with the Mountaintop Express lift (http://www.skilifts....?showtopic=9726) or the Kensho SuperChair (http://www.skilifts....?showtopic=9746) if I didn't live in Denver.
The coil spring grip option seems to be the only remaining holdover from the CTEC merger. Other than the general layout of the towerheads, everything else is Doppelmayr these days, even for the old CTEC loyalists like Deer Valley, which has 4 Uni-GS lifts with Garaventa chairs, but installed a Uni-G with Doppelmayr EJ chairs (and coil spring grips) in 2012.
Beaver Creek is the only old CTEC customer that comes to mind that started using the Doppelmayr designs right away, starting with the Birds of Prey Express in 2003. What's the last lift to have the Uni-GS and Garaventa chairs?
snoloco's Photo snoloco 14 Jan 2014
Don't the fixed grip drive terminals still have some CTEC designs in them? This is the Lookout Mountain Triple at Whiteface which appears to have a Galaxy drive terminal, yet everything else is Doppelmayr. The return is also CTEC. This lift was built in summer of 2008 and opened in January 2009.
This post has been edited by snoloco: 14 January 2014 - 04:17 PM
Peter's Photo Peter 14 Jan 2014
I believe both of these terminal designs have been discontinued since that lift was built. The CTEC lift shacks live on though
This is the Skyline Quad at Sugarloaf, ME. It appears to have a slightly different drive and return, although they still use similar aspects to the ones from the Whiteface, NY lift above.
The image insert isn't working for the picture of the return, so here is a link to it.
http://data:image/jp...IQgK0IQmp//2Q==
This post has been edited by snoloco: 14 January 2014 - 04:42 PM
DonaldMReif's Photo DonaldMReif 14 Jan 2014
Let's get back on topic.......
Peter's Photo Peter 20 Jan 2014
A couple new pictures from the Sea to Sky Gondola Facebook page. I would definitely check this out passing through on the way to Whistler.
DonaldMReif's Photo DonaldMReif 21 Jan 2014
I guess the Sea to Sky Gondola is not for the faint of heart.
snoloco's Photo snoloco 22 Jan 2014
Or those afraid of heights.
DonaldMReif's Photo DonaldMReif 22 Jan 2014
That was kind of what I meant. That gondola would probably give me a lot of reminders of what it was like when I went up the Jackson Hole tram in the summer of 2010. I mean, that was a tram and this is a gondola, but still....
floridaskier's Photo floridaskier 22 Jan 2014
What's up at the top of the Sea to Sky Gondola, is that a restaurant up there?
Peter's Photo Peter 22 Jan 2014
Sounds like it will be your typical scenic lift with a restaurant, gift shop and trails at the top. There is also a trail from the base to the top but no free ride down if you hike up.
DonaldMReif's Photo DonaldMReif 29 Jan 2014
Cabin spacing on the Sea-to-Sky reminds me a bit of photos I have seen of Crystal Mountain's gondola.
DonaldMReif's Photo DonaldMReif 05 Mar 2014
I mentioned that A-51 and Checkerboard at Keystone both received additional modifications from Doppelmayr in the form of new lifting frames on their towers.
This link has better pictures:
http://www.remontees...rtage-1615.html
The photos firmly establishes A-51 as being a frankenlift as it is a Lift Engineering double chairlift, with used Riblet bail-chairs, and Doppelmayr sheaves, upper bullwheel, and lifting frames.
boardski's Photo boardski 05 Mar 2014
I am surprised they used the original Yan grips with those Riblet replacement carriers. Were the Riblet internal grips not compatible with the haul rope or was there another issue?
2milehi's Photo 2milehi 07 Mar 2014
Those aren't Doppelmayr sheave on the towers and Joe Grumunger who came from LE designed the lifting frames.
snoloco's Photo snoloco 12 May 2014
The Sea to Sky Gondola is operating and open. They do ski touring on it which I didn't know they did. This video shows some of the trip up as well as the stations. It also confirms that the Sea to Sky Gondola is a bottom drive lift.
https://www.youtube....h?v=8ReU9p4bDCY
martinnv's Photo martinnv 21 May 2014
I hiked up the Sea to Sky gondola about a month ago, while it was still closed. I measured the vertical rise at about 845m (from 40m to 885m). Here are some pictures.
Peter's Photo Peter 21 May 2014
Thanks for the pictures, Martin! :kewlpics:
floridaskier's Photo floridaskier 21 May 2014
Great shots. Anyone know why it has European style towerheads?
