New Lifts for 2013
311 replies to this topic
#261 Peter
Posted 25 July 2013 - 06:33 PM
Sounds like Vail is now going to build two new quads at Mt. Brighton, one to replace the Green and Blue lifts and another to replace Yellow. In addition to relocating Silver.
http://news.vailreso...ntsepicpass.htm
#262 jaytrem
  • 217 Posts:
Posted 26 July 2013 - 06:17 PM
Eagle Point in Utah is moving their old platter lift over to the expert area this summer. They had this on the trail map a few years ago as a future lift, currently they use a cat to get people back up to the lift. Upon further reading it sounds like this will be at the top of the mountain, not the bottom where they had the future lift on the map. They're also removing the old Holly double that hasn't run in quite a while.
This post has been edited by jaytrem: 26 July 2013 - 06:40 PM
#263 Mthomas940
  • 1 Posts:
  • Interests:Lift Safety and training
Posted 25 August 2013 - 01:26 PM
I know Im a bit late to the party. Alyeska Resort is replacing Chair 6 this summer.
#264 egieszl
  • 92 Posts:
Posted 27 August 2013 - 07:10 AM
Snow Valley (Running Springs, CA) has photos posted on their web site of a truck delivering a new chairlift. Does anyone have any information? The ski area says they'll make an announcement soon.
http://www.snow-valley.com/
#265 Peter
Posted 27 August 2013 - 10:39 AM
Looks like the first new Partek lift in the west since 2004.
#266 vons
Posted 27 August 2013 - 04:09 PM
I think it is a LPOA lift.
#267 Lift Dinosaur
  • 2,077 Posts:
Posted 28 August 2013 - 04:12 PM
Definitely LPOA sheave assemblies....non standard cross arm?
Modification to get rid of YAN aluminum sheave assemblies???
#268 DonaldMReif
Posted 29 August 2013 - 12:52 PM
As of at least yesterday, Vail has installed all of the new lift towers for the Mountaintop Express. Based on the view from the camera, it will have combination assemblies at towers 5 and 6, where the original quad had a hold-down tower for tower 6. I also see the haul rope sitting on the ground next to tower 2.
#269 JSteigs
  • 115 Posts:
Posted 29 August 2013 - 06:12 PM
The cross arms have changed a little bit as of last year. Looks like LPOA to me.
#270 vons
Posted 30 August 2013 - 07:05 AM
I am sure Lift Dinosaur knows the LPOA product well :wink: those tower heads different in many details.
#271 Lift Dinosaur
  • 2,077 Posts:
Posted 30 August 2013 - 08:18 AM
JSteigs is correct. They only tower heads I got up close with last year were at Vail for the Gondola, and it used a different cross arm design with the Leitner 550mm sheave trains.
The diagonal cut on the end of the cross arm and the smaller x-y bolt holes threw me until I did some research. :blush:
This post has been edited by Lift Dinosaur: 30 August 2013 - 08:20 AM
#272 vons
Posted 30 August 2013 - 10:14 AM
Looking at LPOA's Gallery of projects it looks like sometime last summer they switched to this design. Dino what is the reason behind or presumed advantage of this change?
This post has been edited by vons: 30 August 2013 - 10:15 AM
#273 DonaldMReif
Posted 30 August 2013 - 12:56 PM
Terminal parts for the Mountaintop Express have arrived. They were sitting next to the Wildwood Express on the Mid-Vail camera today.
#274 liftmech
Posted 31 August 2013 - 04:30 AM
The diagonal cut goes back to the first PSA detach models in the States-- the Flyer has them-- but the smaller X-Y bolt holes look like they'll prevent proper alignment unless the tower is exactly correct in line. I also notice the lifting eyes have changed to what everyone else was already using. You guys noticed that no-one uses the plastic wheels the way the book says, eh?
#275 JSteigs
  • 115 Posts:
Posted 01 September 2013 - 02:53 PM
Actually thy have done away with the y bolt, its just the x (horizontal) bolt. The axle rest on a plate inside the cross arm, and plumbing the sheaves is done with a shim where it rests at the end of the cross arm. Also the amount of gauge adjustment that can be done by sliding the axle in and out is reduced, which is why the x holes are smaller.
#276 liftmech
Posted 02 September 2013 - 04:41 AM
Interesting.
#277 egieszl
  • 92 Posts:
Posted 15 September 2013 - 05:16 PM
More information is available regarding the lift project at Snow Valley. They are basically replacing (upgrading) parts of Chair 13 (YAN Triple) with new crossarms, sheaves and carriers. Leitner-Poma is the supplier. On Facebook the ski area said they hope the heavier carriers will allow them to run Chair 13 in higher winds than the YAN lift could handle. They are also hoping this upgrade goes well so they can establish a relationship with Leitner-Poma for future lift upgrades. It's interesting since Chair 13 is their newest chairlift.
Long range Snow Valley has indicated that they'd like to install a detachable quad chair. I would also like to see them get Chair 4 (Riblet Triple) working again.
#278 MNSkier
  • 72 Posts:
Posted 16 September 2013 - 04:35 PM
Lutsen has put an announcement about the caribou chair on there website.
http://www.lutsen.co...bou_express.cfm
#279 MNSkier
  • 72 Posts:
Posted 19 September 2013 - 05:11 PM
Towers are flying tomorrow at Lutsen
#280 Peter
Posted 27 September 2013 - 06:53 PM
Alpine Valley, Ohio is getting a relocated triple chairlift in addition to the quad that was previously announced. From somewhere in Utah.
