New Lifts for 2013
#41
Posted 05 October 2012 - 05:28 PM
#42
Posted 06 October 2012 - 12:36 PM
#44
Posted 07 October 2012 - 08:54 AM
As for new versus continued reconditioning, I'm sure one could draw up a comparison if one had access to parts pricing and general labour costs (which I don't for our area, at least).
#45
Posted 07 October 2012 - 10:51 PM
#46
Posted 15 October 2012 - 08:27 AM
Aussierob, on 07 October 2012 - 10:51 PM, said:
It's not so much that companies are "happier" to pay higher maintenance costs. It's just that there usually isn't a good reason to replace a lift, if it's still safe and replacement parts are available. Most replacement lifts offer some sort of service improvement, such as the trade of a fixed-grip for a detachable.
#48
Posted 01 December 2012 - 02:04 PM
The resort's Peak 6 project would add nearly 550 acres of skiable terrain, two lifts, a restroom facility and warming hut.
Some opponents say cutting trees to make more ski runs could hurt Canada lynx, while some residents have objected because they fear overcrowding in town.
The plan has the support of 45 individuals and environmental groups.
Vail Resorts Inc., which operates the resort, says it expects to have the new terrain ready for the 2013-2014 ski season.
Posted 01 December 2012 - 06:24 PM
Sounds good, hopefully our dismal season will improve so it will not put a damper (no pun intended) on the plans. All these expansion plans and "master plans" sound great but without snow, will not be worth much.
This post has been edited by boardski: 01 December 2012 - 06:26 PM
#50
Posted 01 December 2012 - 06:30 PM
JSteigs, on 22 October 2012 - 07:40 PM, said:
I wonder how long it will be until it is available to the public also. Probably not a bad idea. Depending on which line one is skiing, that can be quite the hike on very rugged terrain. I wonder if the lift would go where the snowcat runs now or if it would go all the way to the top. The latter would like some excavating due to the terrain up there. Interesting though.
#51
Posted 05 December 2012 - 06:50 PM
This month the Club announced to its members that the Lucifer Quad, a 1991 Borvig Quad (previously scheduled for relocation in the summer of 2013 to "Pod D" ) will instead be sold. The Hallelujah T bar (the Pod D lift ) will be removed in the summer of 2013, and a brand new chairlift (capacity not announced yet) will be built in its place. Wow all lifts replaced in less than ten years.
#52
Posted 19 December 2012 - 07:16 AM
#53
Posted 28 December 2012 - 08:39 PM
This post has been edited by DonaldMReif: 21 November 2013 - 09:06 AM
#54
Posted 10 January 2013 - 07:42 PM
Project website: http://seatoskygondola.com/
http://m.squamishchi...late=JQMArticle
March gondola construction start targeted
The creators of a $25 million tourist gondola to a ridge between Stawamus Chief and Shannon Falls provincial parks are hoping for a March construction start date on the project, with a planned opening in May 2014.
David Greenfield, one of the two main principles of Sea to Sky Gondola Corp., on Friday (Jan. 4) said the gondola proponents are busy completing design work and getting set to apply for building permits from both the District of Squamish (DOS) and Squamish-Lillooet Regional District (SLRD).
The gondola, which initially is to include 20, eight-passenger cabins along the cable tramway that will top out at 2,700 feet above sea level, is to be built by Swiss-Austrian consortium Doppelmayr Garaventa, the world's largest manufacturer of aerial tramways, Greenfield said.
“We're excited to finally get this thing started,” said Greenfield, who along with business partner Trevor Dunn first presented the idea to the community in July 2011.
The proposal then went through zoning approval from the DOS for the base area and the SLRD for the top station and trail network. A change to the Parks Act was required to remove a few acres from Stawamus Chief Provincial Park for the tramway pass-through, and issuance of a Park Use Permit to allow for construction.
“We're getting all the I's dotted and T's crossed as far as our park permit goes,” Greenfield said.
“I don't think anyone's actually done this before. We've got to do tree surveys to see how we need to do things as far as whether there are significant trees that have to be cut,” he said, adding that the level of detail required for that work is extensive.
“I think the fact that we're putting this through a protected area means that we're being held to a new and high standard — which is fine.”
Greenfield said the actual construction start date depends to a large degree on the weather, but the proponents are hoping to get going sometime in March. Because there's likely to be snow on the upper slopes for the next few months, actual construction will begin with the base area, with work on the top station beginning as soon as conditions allow, he said.
Once the gondola opens, the proponents have projected it will attract around 300,000 visitors per year and employ some 30 people. The proponents initially targeted late summer 2013 as a hoped-for opening date for the gondola, but pushing it back to spring 2014 “gives us an opportunity to do a bit more pre-marketing and to attract that visitation,” Greenfield said.
He estimated the project will cost around $25 million to build. That compares to $51 million for construction of Whistler's record-setting Peak 2 Peak Gondola, which opened in December 2008.
The choice of Doppelmayr Garaventa for the actual lift system was an obvious one, Greenfield said.
“They're a big company but it's still more or less family run,” he said. “They've made quite a name for themselves and there's not many places in the world that don't have at least one Doppelmayr lift.”
The tramway will include 20 passenger cabins initially with the option of increasing the number of cabins if and when the demand increases, Greenfield said.
“We're designing it to accommodate more as the business ramps up,” he said. “Because it's a detachable lift, you can actually add cars to increase capacity when you need to.”
The company is planning a by-invitation-only celebration on Thursday, Jan. 24, from 7 to 9 p.m. at the Cornerstone Building, No. 401, 37989 Cleveland Ave. Those who have received emailed invitations and wish to attend are asked to RSVP by Jan. 18 to info@seatoskygondola.com.
Posted 18 January 2013 - 05:16 PM
http://www.whistlerb...ifts/index.aspx
- just giv'r likes this
- Like This
Posted 18 January 2013 - 09:24 PM
Most likely the old Crystal will go up for sale as components.
#57
Posted 23 January 2013 - 07:54 PM
#60
Posted 25 January 2013 - 05:51 PM
