Wanted: OLD Doppelmayr t-bar parts
Posted 10 January 2013 - 08:44 PM
We need sheave parts for our mid-'50s Doppelmayr t-bar - specifically axles, hubs, and hub spacers for compression sheaves. I can still get a few parts readily from Doppelmayr, but they can't find parts to match these sheaves. If anyone out there has an old (OLD) t-bar laying around, or know someone who does, I'd be eternally grateful for a point in the right direction!
Thanks!
John
Posted 11 January 2013 - 05:50 AM
While I can't help you with the parts, I can offer you a suggestion.
My experience is that as these lifts become fewer and fewer in Europe the Manufacturer no longer stocks the parts- they become special order. As the need dwindles further the Manufacturer will no longer produce them, but will have them made by a sub-supplier which results in higher costs and longer lead times. Other parts simply become "obsolete".
I would recommend that you see if you can get a hold of the original drawings from Doppelmayr and try to find a machine shop near you to fabricate them. Another issue will be that the parts in Europe are made from metric stock (i.e. 25mm tubing vs 1" tubing) so the machine work required will be greater.
Hope this helps.
This post has been edited by Lift Dinosaur: 11 January 2013 - 06:03 AM
Posted 11 January 2013 - 05:30 PM
Thanks very much for your input. Unfortunately Doppelmayr has so far been unable even to find the drawings (!) for whatever lift we have. Part of the issue is that we don't have any manuals, install sheets, etc. to give them a starting place. If they can't come up with anything, we may start taking some of the spares to a machine shop to have them replicated. You're very right about the metric issue - we've already had to have a shop redo some work on a sheave train hangar bracket because they tried to get away with using a "close enough" imperial-sized stock instead of machining down to metric.
I'll engage with Doppelmayr as well about the route Kelly is suggesting - start buying parts that Doppelmayr does still make and build new sheave trains one at a time to accommodate whatever the design differences are. That's probably the better solution if we want to keep this lift going long-term.
Then again, maybe someone will give us a million bucks in their will and we can just get a new lift put in ...
JRW
Posted 11 January 2013 - 07:58 PM
Posted 13 January 2013 - 08:46 AM
mikest2, on 11 January 2013 - 07:58 PM, said:
Thanks, Mike. I'm travelling for another couple weeks and don't have access to my photos. Will send/post some when I return. You are right that it is the widened sheave with the spacer between the liner and the sideplate (or what's left of the spacers - they've been pretty chewed up over the years).
John
Posted 13 January 2013 - 09:42 AM
I did have a couple pictures with me after all. Not sure if these are enough to positively ID anything.
Thanks,
John
This post has been edited by JohnRW: 13 January 2013 - 09:42 AM
Posted 13 January 2013 - 10:21 AM
Posted 13 January 2013 - 05:23 PM
Posted 13 January 2013 - 05:38 PM
mikest2, on 13 January 2013 - 05:23 PM, said:
Mike - It's a 1" rope. Fingers crossed - thank you!!
